Originally Posted by St Runner
Yes, the clutch switch at the bottom of the clutch is for the starting circuit. the one at the top is for the cruise control. In the auto (all of this is in a 97 I am assuming the 2000 is the same) the starting circuit runs to the park /neutral switch. Wether you put in the 5speed engine harness or not you will still have run a wire from where the starting circuit went to the park/neutral switch over to where the clutch is since there is nothing there in your 4runner. It is a simple ground wire, meaning all the switch does is complete the ground so that the circuit is active. You can ground that starting circuit wire anywhere on the body and your 4runner will start whenever you turn the key
Lol I wish I understood any of this. I get the clutch stuff but not the additional information. Is there any writeups out there that go more into depth with this?
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
