The 265 70 17 Wildpeak, at least the SL version, is 9" wide, it is basically a 285 when it comes to width (not height).
Using stock wheels, my driver one rubbed a little on the front fender, as with AZ Craig. I removed the mud flaps immediately anyway so no recollection on that. For the rest, as mentioned already, it has to be the lift plus alignment specs.
