View Single Post
Old 06-25-2020, 09:51 PM
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by s13vlad View Post
Question for people running Bilstein 6112's! I just got mine in today and the instructions say that the 5/3 settings give 1.6 inches of lift, and the 6/4 give 2 inches. This is different from before where where they said 5/4 gives 1.85 which is what I intended to do... Has anyone installed it recently, and if so, what did you go with? Did the 6/4 actually give you 2 inches on a non KDSS model, or was it more? I tried to call them to ask what has changed to have them tell you to go 2 clips lower on one side, versus 1 before, and he basically told me he had no idea...
It all depends.
With 600lb springs and the 1.2 setting (4/2) I got more like the 0.8" setting with just 3/16 steel skids and sliders. With the 650lb springs and everything else the same, I am getting a bit more than 1.2" in the front.
I personally replaced the springs because the 600lb is too soft with the 6112 for any serious desert use.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
