Originally Posted by cmoekim
You can reuse your OEM metal brackets/hardware with the Metra kit. First, you'll have to drill out the alignment nibs so they sit flush with the plastic Metra brackets (you still use these to mount the dash kit to the head unit), but that should leave you with enough holes lined up with the threaded DIN mounting points on the Pioneer to screw/bolt the whole assembly together.
Do you even need to mount it to the Metra dash kit? I just mounted it with just the OEM brackets to the dash and it seems to be just fine. The only drawback to that I can think of is if I want to remove the dash kit I have to take the display off the unit first. Anything else I’m missing?
