Originally Posted by I4CUTigers
Was curious if anyone ever found a good solution to the front bumper and it’s tendency to pop at the corner near the headlight?
I had my bumper replaced due to someone hitting me and the replacement bumper tabs on the new bumper are very malleable on the passenger side, so every time I pop it in, it immediately pops out. The driver side is more rigid, and therefore the tabs hold into the female coupler just fine.
I was wondering if there is any way to make the plastic injection line where the tabs rest any stiffer, which should cause the tabs that rest on that protruding line to function correctly by holding in the female coupler.
Thank you
Did they use an OEM or Aftermarket bumper? Either way, I would be driving back to the shop and asking them to fix it. It should not be popping out unless you hit something. Either the bumper is bad, the tabs on the bracket are bad, or something is wrong with the fender alignment. I have 20 years experience in the body shop, it should not have been delivered if they couldn't keep the bumper snapped in.
