Originally Posted by Devbot
So I've been looking into getting some steelies recently, and decided on 16x8 with 4.0BS since I saw lots of good things said about this set up, and think it looks badass to boot. I plan to throw some 285/75s on them, and will be done with a 3in lift
However, I see lots of people on here say they run various wheels with these specs without problems, but damn near everytime I find a set I like the reviews on the webstore mention someone with a 3rd gen T4R needing 0.25-0.5in spacers to clear. Is this something dependent on the wheel? Maybe pertains to 13WL/13WG calipers? I do plan on doing the TBU in the next few months, fwiw
Just confirming what I need to buy
285s would be cutting it close with a 3inch lift but all you need is a 'BFh and thatll fix that..
i believe the difference in calipers are between 15inch factory brake setups
& 16 inch factory setups
Also the upper balljoint/UCA may hit the inside sidewall probly should order a .25 " spacer
