Originally Posted by Nape4
i live in very very bad roads area
everythings is holes and mountain roads
its kinda jungle
if i go with ild man emu
can you tell me whats parts i need to get in the kit?
of the old man emu?
because my mechanic told me that if i choose old man emu i will need to have another extra parts
Having been to Costa Rica myself, I would say to get that Dobinsons or OME stuff and lift it up a little because there's some fun stuff to do off-road!
When it comes to a lift kit like that it will come with everything you "need" depending on where you get it. Being front shocks/coil-overs and rear shocks with springs. It's recommended to get aftermarket upper control arms as well if you go with a lot of lift, so you can correct the alignment properly. Check your UCA/LCA bushings as well as ball joints while you're there so you may save some time later. No matter what you will at minimum need an alignment after.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
