Originally Posted by ElectroBoy
You may have to research this. I thought I read somewhere in the forum that the 10-13s siderails were wider apart at the rear and narrower at the front. Try measuring yours as accurately as possible. The 14+ Side rails are the same width throughout the range: 40.5 inches. The NiseRack brackets plus tolerances take up about 5/16 inch, therefore the crossbars are 40 3/16 inches.
This is correct. They get closer together towards the front. LFD has adjustable crossbars to deal with this. You could uses these brackets and measure very carefully and order the right length extrusions.
