Originally Posted by STX4Runner
This is correct. They get closer together towards the front. LFD has adjustable crossbars to deal with this. You could uses these brackets and measure very carefully and order the right length extrusions.
3rdgendreamin
If you can give me the length of the rail from end to end and the distance apart at both ends I can tell you what length rail you need to order. Depending on the offset from end to end you should be fine. If it's extreme that's another story but I image it's not. The bars are only 3" wide and I would have to guess across a 3" span it's minimal.
If you like I can send you out a "test" bracket and backing plate tomorrow to see if they will work in your rails. If the LFD rails fit I would imagine mine would too.
Also at this point I have 15 sets of 4 brackets ready to ship tomorrow if anyone is interested.
