Originally Posted by RivMan
Installed the SuperPro’s last night.
Extremely impressed. The inner sleeve is captured, but not bonded to the poly. With the alignment cams torqued, the arms swing freely. Everything fit great, and so far I’m very impressed with the quality.
I installed these with JBA UCA’s.
I requested ~4.2 degrees of caster and slight negative camber. They got it just right! All 4 alignment cams are almost centered. Tons of adjustment in any direction.
-Rob
What made you go with ~4.2 degrees of caster and slight negative camber?
