Originally Posted by SHagood
What made you go with ~4.2 degrees of caster and slight negative camber?
At least in the drifting world if you have a slight negative camber when the wheels are pointed straight ahead then at full lock the tire will be “flat” with the ground. Although normally you’d see -1.5 or “less” degrees of camber to actually make a difference.
