I am super curious on this one… Did your oil leak get fixed by replacing the parts you mentioned?
Thanks.
John
Originally Posted by Joe-Runner
So, while browsing the "What did you do to/in your 5th Gen today" I came across a post from
@ EddieV4runnin
that intrigued me. He too thought at first he had a PS pump leak but is fairly certain it was actually the passenger-side VVT-i line. My leak seemed to be emanating from the lower connection to this line as well, so I figured why not go ahead and swap it out!
Just completed it two nights ago and so far it's clean under there. Did it fix it? Don't know yet.... but it may be worth looking into in your case. Unfortunately, it's a biotch to see up in that area from above, below, or from the wheel well. Here's the parts list for the job anyway. Good luck to you!
15772-31010 Pipe, Oil
90401-16043 Bolt, Union X2
90430-16016 Gasket, lower end of the line
90430-16012 Gasket, to Valve cover X2
Bolts may not be needed, but I replaced them anyway.
Banjo bolts are 48 Ft Lbs
Power steering pump bolts are 32 Ft Lbs
You need to disconnect the PS pump and let it hang to access the lower bolt and remove the air filter to get easier access to the top bolt. Whole job took me 2.5 hrs from beginning to end.
Here's a few pics. Does yours look like this?
