View Single Post
Old 07-14-2020, 08:45 PM
Eitek1 Eitek1 is offline
Eitek1 will become famous soon enough
Originally Posted by uh0h50 View Post
I've only had LFD Off Rack cross bars on stock rails And then switched to an entire LFD roof rack, so I can't really compare. But due to the design of these aluminum cross bars, do they retain water? If so, would there be any unforeseen issues? Perhaps I'm overthinking it.
What SN_85 said is correct. They may retain a little water but it shouldn't cause any issues. If the water was to seep out at the end of the bar it would just run down the face of the bracket and drop harmlessly on your roof. It wouldn't even have access to the inner part of your roof rail (which is open to the weather anyway).
If corrosion was an issue I understand. The only part that could possibly rust is zinc phosphate coated and is made for this type of application. Everything else won't rust or corrode due to the properties of the material.
What was your concern specifically? Maybe I can answer that better.
Eitek1 is offline   Reply With QuoteReply With Quote
