Originally Posted by Kanoe
Steering rack bushings are easy to check. Have someone move the steering wheel left to right while you watch the steering rack for movement. There will be almost no movement on tight bushings.
If they are real bad you’ll see rub marks from things slopping around
You can use the same method to get a rough idea on the other components also.
Ok, I’ll make sure to check, thanks! Do you think this could be causing the slop in my steering?
