Originally Posted by eleven14
Your issue is very likely the system being low on refrigerant and you'll need to get the system recharged (with dye) and check for leaks.
I'm dealing with the same thing (same symptoms) and after evac/recharge, it's blowing ice cold. Will check for leaks in a few weeks and/or if the symptoms return. Tech said it was pretty low.
Lots of threads on it, seems pretty common at 10+ years and 100k+ miles. Fingers crossed that mine isn't a leaking evaporator core. Good luck
Thanks for the reply. If it was the refrigerant why would the passenger side be cold? They use the same a/c and heater element on both sides, the only difference between driver and passenger side is the hot/cold air ratio, right? At least that's how I understand it.
