View Single Post
Old 07-19-2020, 10:36 PM
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Lift, suspension, wheels, and tires
In progress.......
My lift except I bought individual components and had to build the front coil overs with new KYB Top Hats.
Front
-Bilstein 5100’s set at 0 with Eibach springs, 1/2” ToyTec spacer on driver and 1/4” on passenger, new KYB top hats. ToyTec Differential drop kit. ToyTec sway bar relocate kit, and red energy sway bar bushings.
Rear
-Bilstein 5100’s set at 0 With ToyTec Supeflex springs. 2nd Gen. rear sway bar links with red Energy Poly bushings. Red energy Poly rear sway bar bushings.
I didn’t get any before measurements to determine just how much lift I gained, it seemed pretty substantial though. I took very few pics though the lift process unfortunately, nor document anything.
Before lift
After lift with stock wheels and 265/65/17
You can see the differential drop kit
We didn’t remove either the UCA nor the LCA, just the sway bar links and the ball joint tapered bolt nut for the UCA. Made it hard to compress getting it bolted back together so had to get a little creative lol. Had a floor jack underneath and got to the point where it just started lifting the whole vehicle so we had to “influence” it a bit.
A lot of rusted bolts and issues. Blew through a lot of PB Blaster! The front passenger rear sway bar weld nut inside the frame wound up breaking loose about halfway unthreaded. Wound up having to drill the frame out, get a wrench on it and replace the nut. I was going to have the nut welded and close the frame, but for now just painted it and left it open.
Here is the weld nut which was broken loose, horrible design lol
You can see a shot of the sway bar relocation kit and the red energy sway bar bushings.
Rear Moog (Japanese made) sway bar end link for a 2nd gen. They are 1” longer than the 4th gen links and virtually took all the preload out. Also put on red Energy Poly bushings and red energy rear sway bar poly bushings
Wheels & Tires
-Level 8 MK6 in Gunmetal Grey 17”X8” 0mm offset W/TRD Silver caps.
-Falken Wildpeak A/T3W 275/70/17
-TRD silver valve stem caps
Tires seem great so far, high mileage warranty rating (I think like 55,00mi) and very quiet on the road.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
