Installed my back up camera. That little tiny camera sure is a lot of work lol. The first pic. Is under the floor trim and shows the red wire with yellow stripe that I used to tie into for my reverse trigger on the driver side. Not to be confused with the yellow wire with red stripe (it got me), have to look closely.
Ran the camera wire in through the grommet.
Didn’t take any good pics apparently of the inside but you have to be careful the wire does NOT get in the way of the window or will cut it. I ran mine tight on top of other wires existing.
Used a coat hanger to fish through the wire loom above the hatch.
Hooked the power wire on the Camera to an ignition +
Rear camera
Installed my front camera this evening on my bull bar. I am able to view at any time and can toggle back and forth between the rear and front camera. Plus it goes in to the rear view mode when in reverse with parking grid if chosen.
It will be nice to finally see in real time what’s on the other side of that hill as it’s crested while off-road. Only problem is with the Pioneer the image is reversed. There is no way to flip the image mirrored the opposite direction. For the front cam whatever it shows on the left is actually on the right.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
