View Single Post
Old 07-19-2020, 10:51 PM
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
XM hidden antenna install
Took off top Rack front corner cover
Ran Antenna wire under passenger windshield trim and through firewall.
Mounted receiver inside just above cup holder and behind taco holder
Cut a piece of metal to fit inside corner piece
Drilled it out and put bolt through it. Stuck magnetised antenna to it
Snapped cap back on and only part that’s visible if you look is a small piece of antenna wire. Thought about drilling a hole through the base and running up through the bottom but the plug is pretty big. The antenna receives signal through the plastic cover no problem. Comes in clear and doesn’t lose signal, zero issues.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
