Originally Posted by Jpilot
The rack is on! All I can say is, it is awesome. Fitment and design are right on. Rooftop tent will be going on next, and I am sure it will hold. This thing is solid. Only issue I had was one of the holes on the beam from TNutz was not drilled far enough in. Just need a shorter bolt for that one.
So glad you like it. As I’ve said, I worked on this a while to ensure everything was right before I shipped anything. It’s hard to describe just how solid this thing is without seeing one in person.
Sorry about the short threaded hole on the crossbar. The threads are a 1/4-20 pitch. The holes already exist in the crossbars Tnutz just threads them. Chances are they didn’t run the tap deep enough.
If you pick up a 1/4-20 tap and some WD-40 you can run the tap in and you won’t even have to remove it from the roof. You’re also fine with a shorter bolt. You probably don’t lose much strength.
