Real Name: Carlos V.
Originally Posted by Harlock
Thank you! As mentioned, I did replace the bottom weatherstrip, which was stupid-easy. Installing it took less time to do than taking the part out of the plastic bag. Mine was really worn out, but replacing it did nothing to stop the water.
It seems odd that the plugs at the bottom are solid since some moisture would have to get in due to the window. My 4Runner is also an 2007 (SR5 4WD). Did Toyota make different plugs with drain holes for other years/generations? If so, I wonder if they'd fit ours.
Pics from today
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
