Real Name: Howard J. Turkstra
Sorry this post is so long! I didn’t originally plan on posting so much info.
I am doing this mod with L and R Moforkit lenses, 2 Sylvania ZEVO LED 7443R (red) bulbs and 2 TOMALL 7443 T20 sockets I bought from Amazon, and some 14 gauge wire I bought locally at Home Depot. I plan to splice into the factory tail light/brake light wiring, and not the trailer wiring. My lenses will hopefully have just running and brake lights - no turn signals, hazards, reverse or fog lights. The 7443 LED bulbs are similar to two filament standard bulbs.
I spent a couple hours today removing the rear bumper cover to get to the reflectors. I’m glad I did, because after I got the bumper cover off, I couldn’t remove the rusty nuts from the factory reflectors. The nuts just spun forever without coming off. To get the factory reflectors out of the bumper cover, I had to destroy them with a hammer and a dremel tool, with thankfully no damage to the bumper cover. I now have two nuts rusted onto very short bolts with a small flat retainer on the end of the bolt to use to attach the new lenses. My local hardware store had nothing remotely close to the nuts and bolts that I removed, so now they’re soaking overnight in PB Blaster. Hopefully I can reuse the nuts and bolts so I don’t have to hit up the local Toyota dealer or an auto parts store tomorrow.
Getting the bumper cover off was a bit of a pain, as there are two 10mm bolts close to the trailer hitch that couldn’t be removed because the hitch was in the way. While loosening/removing the hitch, ALL 4 (!) 13mm bolt heads snapped off. (I should have prepped them with PB Blaster.) None of the 4 17mm heads did, which is why I stupidly assumed the 13mm bolts would also come off easily. I was able to loosen the 4 17mm bolts at the trailer hitch enough to get the 2 10mm bolts off without having to remove the hitch completely. After all that, the bumper cover came off very easily.
Now, as part of this project, I have to remove the four snapped off 13mm bolts from the frame rails, rethread the four frame rail holes, and install four new 13mm (or larger) bolts. Fun!
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
