If the charge light is not on in a Toyota, the alternator is working fine. All Toyota alternators made since 1978 are internally regulated, there is no external "voltage regulator" to break.
It sounds like you just need a new battery. If the battery has not been load tested...do that first.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
