Removing all the airbags would net you around 40lbs of weight decrease. You would not believe how much the side curtain airbag barrels and brackets weigh.
If you are trying to get less parasitic drag on the engine so that you pull hills easier I would look into a custom undersized crank pulley to underdrive the accessories.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
