Yup, radiator time. After 15 years you probably have enough scaling built up inside to reduce cooling enough to cause the issue. Seen it in a lot of vehicles - cools fine all winter but come summer it starts to overheat.
As long as your AC blows cold, no need to replace the condenser; or, at the very least do the radiator first then check AC output.
Between outfits.
