Originally Posted by bjr26
That is correct, there is no "4 HI" light. Under normal operation, when you switch the dial to 4H, the green drivetrain light should come on and stay solid green. From what you've described, it does sound like the actuator was not regularly used which would explain why neither 4H or 4L is engaging. However, that doesn't explain the 4H light coming on and staying on; that seems like a potential problem with your engine control module.
Is it possible checking any codes will pop up with no check engine light?
