Ok so after doing some reading, it seems like the front brakes are supposed to be bled the traditional way by pumping the brake pedal, and the rear you just hold down the brake pedal, open the valve, and let the booster pump do the work for you. The rear brakes seem to be bleeding normally. The pump comes on and a lot of fluid comes out. The issue is with the front. The booster pump comes on when bleeding the front, which I thought wasn’t supposed to happen. Is that normal? Also, very little fluid is coming out either side of the front. When the front bleeder valves are opened, the pedal slowly falls to the floor. Is that normal? Am I supposed to follow the pedal to the floor? That’s what I’ve been doing but worried it could damage the master cylinder?
