Originally Posted by originalg00kster
It was opposite for me. The fronts were pushing fluid out but the rears weren't until I turned the car on. When I had the car on, I was able to bleed all 4 with no issues. I just did the normal brake bleeding procedure on all 4.
I believe the brake pedal depressing to the floor is normal when you open the brake bleeder valves. That's what happened when I did it as well.
Did you hear your brake booster pump come on? I hear a loud motor sound when I press the brakes. Anyone know what the deal is? Is the booster pump bad or maybe just has air in it?
