Real Name: Todd
Real Name: Todd
Just a note, there are no lifters in the 2uz motor. It's overhead cam.
Pretty sure you can swap in a VVTi motor without doing the ECU and engine harness since you already have a 2uz. I'm running just the VVT intake manifold and throttle body on my 2003 non-VVT engine without issues. The VVT manifold has variable length intake tracts that are vacuum controlled, not ECU controlled. The VVT motors do have air pumps but there are several threads covering eliminating those I think.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
