The first four letters/numbers after DOT indicate the manufacturer & plant code and the tire size code.
The next set of four letters/numbers indicate the manufacturer's identity or construction code. It is a little confusing that they chose to use all numbers in your case (thinking it might be the date code).
These eight letters/numbers are what you are reading on the sidewall of your tire as they are currently mounted (facing outwards).
As suggested by @Sky the date code (final set of four numbers) will be visible on the other side of the tire.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
