Originally Posted by Parkss1181
Sorry to chime in so late.. looks awesome by the way!! I just ordered a set of 285/55/r20 and ordering a set of 20x12 hard rock crusher H704’s on a -44 offset. Little less offset then your wheels and I’m planning on going the 3” suspension lift and 1 inch body lift along with any trimming needed, body chop and flattening the pinch welds. My only question is how did you move the UCA’s forward more to help clearance and also how did you pick the bumper up off the frame to mount and compensate for the 1” gap that it would have had?
You will have more offset than me. The more negative, the wider if that makes sense. I commented on your thread the other day. I'll be interested to see if you can fit them.
I have SPC adjustable upper control arms that are meant for this very thing. The bumper stretches. You just loosen the bottom screws, install body lift and tighten them back down. No modification required.
Sent from my SM-G986U using Tapatalk
