Originally Posted by rc10mike
Im not sure of your system configuration, but if you are using passive crossovers with the mid and tweeter then you wont be able to properly align and EQ the drivers separately. This is only possible with an all active setup. Meaning each speaker has its own channel on the amp. Using passive crossovers severely limits actual tuning ability.
great point and thanks for the input.
i am going with what Sony recommends from a components and connections point of view. Will be using passive cross overs however willing to draw two new wires just for the tweeters (killing the cross over module if its not optimal) to make a straight active connection. in comparison to the attached diagram, i will have identical setup for the front and the rear though. it will take me some trial-error to get everything optimally tuned. thx
Input Connections - Sony XM-GS4 Operating Instructions Manual [Page 6] | ManualsLib
