Originally Posted by Drobs
Since it's the stock size, I'd go with the door sticker PSI.
The door sticker is more based on the P load rating than the size. C and E rated tires typically require higher PSI than a P-Rated tire does.
I had mine installed at a shop that has probably installed over 1000 sets of the BFG KO2 in both C and E rated tires, and that’s just on 4Runners and Tacoma’s haha they put mine at 38psi as they found that was a good psi give or take for the C-Rated tires.
