Originally Posted by Bravo Kilo
For those who have torqued your plugs, what torque value did you use for the front differential drain plug? The guide in the original post says 48 ft/lbs, but my Chilton manual says 29 ft/lbs for both the front drain and fill plugs. Thanks in advance!
Not sure where the 48 ft-lbs came from either, my ‘06 FSM says 29 ft-lbs for both as well. I did it to that spec last time with no leaks/issues.
