Real Name: Skip
Real Name: Skip
I would say you're good to go, if they did indeed replace 8 quarts of the coolant and used the correct Asian pink formula coolant, the V8 takes 13 quarts of coolant, so they replace approximately 2/3rds of the coolant, I would feel good with that on my V8 since these Toyota engine coolant systems run pretty clean as long as you use the correct coolant.
2004 Limited V8
