Originally Posted by cmoekim
You can reuse your OEM metal brackets/hardware with the Metra kit. First, you'll have to drill out the alignment nibs so they sit flush with the plastic Metra brackets (you still use these to mount the dash kit to the head unit), but that should leave you with enough holes lined up with the threaded DIN mounting points on the Pioneer to screw/bolt the whole assembly together.
Trying to picture how to do tbis...couldnt i just take the plastic metra bracket off and reuse the metal bracket with less screws? Im sure it would be secure. Just finished my install..needs to be tweaked a bit. I think i can go one notch lower on the display. Think OP is a tad lower on his screen than mine.
Also need to get new yellow clips..mine wore out during install... Lots of trial and error
Sent from my ONEPLUS A6013 using Tapatalk
