View Single Post
Old 09-05-2020, 11:10 AM
biggestmexi biggestmexi is offline
biggestmexi is on a distinguished road
First, if there is no engine light, an OBDII code reader will not do anything.
Second, you will need to check your ABS codes, which is easy.
  • Find the "DIAGNOSTICS" connector that's on the drivers side of the engine, on the high edge of the intake plenum.
  • In the lower left, you'll find a small plug that pulls out. That's a "shorting pin", pull it.
  • Now use a piece of wire to jumper from E1 to Tc.
  • Go into the truck and turn the key forward.
  • Watch and count the blinks of the (ABS) light.
With the light blinking it will blink a certain number of times and then short pause then blink again. This will give you the 2 digit code. Wait for the code twice as you might have more than one code.
Then you can start from there.
biggestmexi is offline   Reply With QuoteReply With Quote
