Replaced Plugs - Now I have a cam position sensor CEL
Hi All, finally got around to doing some maintenance last night. Did serpentine belt, oil change and of course the spark plugs at 110k.
Immediately after performing the repairs I tried to start the car but am getting multi-terrain select unavailable, traction control light on and CEL. Autozone scan reports back P0393 - Camshaft Position sensor B Circuit High Input (Bank 2). I've removed the negative battery terminal for 1hr+, same result.
From what I've read so far, this sounds like an issue when removing the middle plug on the passenger side and pulling the wire loom a bit too hard thereby damaging the cam position sensor plug? Anyone experience this before? I'm just not sure which cam position sensor this specific error code is referring to, I know there are multiple.
Lastly, with the plastic oil filter housing, I can't recall if it was supposed to tighten to sit flush with the metal it is threading into. Mine is a good few mm away, but tightening any further makes me feel like I'll wreck the o-ring. I did place the o-ring in the correct position, fwiw.
Thanks!
