Real Name: Gary
Real Name: Gary
Update to this saga, just did another pressure test. Pumped up to 16 psi and it held no problem for 15 minutes and I looked around and found no leaks at all.
Then I warmed the engine up and performed the the combustion leak block tester. The fluid stayed that nice dark blue, so I don’t think I have a head gasket leak.
I did replace the radiator cap with a new one, I guess we will see how that goes.
But all this kinda still leaves me scratching my head? I suppose I could pull the thermostat and test that. Does anyone have other thoughts? Maybe I should just replace the water pump?
