I replaced all the lines on mine with copper nickel line which does not rust and is easily bent & flared. 10MM ends in bulk. I also replaced the rear rubber lines while I was there, they are cheap.
I don't see how you could put a previously bent line over the tank without dropping it but one you are bending is doable. Chances are slim you'll get the old one completely out.
Amazon.com: 25 Ft. Roll/Coil of 3/16" (.028" Wall) Copper Nickel Brake Line Tubing: Automotive
Amazon.com: Metric Brake Line Invert Flare Fittings for 3/16" Tube. 10 x 1 mm (Pack of 10): Automotive
