Originally Posted by daytonaviolet
Some things to check.
1. Is the power connected for passenger mirror ? Check for shorts
2. Drivers side mirror, power connected ? Check for shorts
3. Check to see if the main 3 wires (red, blue and white) going to the correct wires.
I’ve spent more time on troubleshooting this than I care to admit, but I’ve completely pulled the system apart and reconnected all the wiring and verified all the wires are hooked up exactly like you have in your guide. I even pulled off the black felt-like wrap from the wires to verify that there aren’t any wires touching underneath.
I’ve tried several different things, but if I leave the ECU disconnected or I don’t plug in the new switch adapter the fuse won’t blow, but as soon as I connect one of those two things the fuse blows. I’m really starting to think that I received a defective wiring harness at this point.
Any suggestions?
-Jake
