I installed mine last week. The console is VERY easy to disassemble, you basically just pull it off. It's by no means something to worry about.
The wire taps they give you with the USB kit are a terrible solution and I'd suggest finding something better for that portion. I'd check out a T tap 2 pin 2 way.
Also it sits relatively high up so I haven't found a great ram mount setup just yet that doesn't block a large portion of view out of the front wind shield. I'm waiting on some nuts/washers/etc to drill a hole in the side for a phone mount similar to the real cheap basic threaded ball mount that people have installed
