Looks like you should look for a roll over donor with the engine spinning backwards my guess is that the oil pump would be pulling the little oil that is in the bearing area away pushing it back to the pan. You can pull the plugs crank the engine to get out any oil pull the air cleaner and wipe out any oil you can get to try and start it let us know how it goes.
