Originally Posted by Old Red
Keep in mind I only have the experience with the one Limited MPX here, but I would venture a guess and say yes, it should be plug and play. Remember, the keyed ignition models have the MPX acting as the Key RF code receiver whereas the smart key system has a separate ECU acting as that system, which then tells the Limited MPX to unlock the doors.
So I guess what I am saying is that the MPX in the Limited is not tied to any part of the smart key system other than being able to accept communications from that system vs. a non-smart system MPX which cannot.
I am impressed with your knowledge.
I was not aware the limited smart key had a separate system which acts as the receiver for the remote keyless entry. Ive had many Toyotas over the years. (currently 91 Supra turbo, 97 Tacoma ext cab 4x4, and just got the 13 4runner limited last fall, so I'm still learning about it). Makes sense that a replacement MPX from a limited would be plug and play.
What is your opinion on the feasibility of having the orig MPX repaired? It appeared to burn the diodes D022 and D024.
