Originally Posted by <<<<
Don't remove the axle. I had same issue on my 4th gen 3 years ago with some milk shake like grease pouring from outer boots. Dealer quoted $750 to replace Boots on both axles and refused to replace clamps only (said rubber isn't soft enough to seal again). I bought OEM Toyota clamps ($ 34 for 4 clamps) and RedLine grease. It took 40 minutes to unclamp, slide boots down the axle, clean and repack the bearings with new grease after inner (smaller clamp was back on). Easy job and no leaks since. G.L.
Sounds easy enough. You have part number by chance for the clamps? When I search online I can only find tie rod boot clamps.
