It should also be noted that if you get Fuel Gauge TSB performed by Toyota it will reset your Odometer to 0, I had mine done at 200,000Km and they had me sign off on it, talked to another guy that fixed my Climate control and he said he can save the Odometer data when he does the Fuel gauge TSB. But I thought the TSB was for Nov 98-2000 MFG Date so it doesn't apply to the OP, and this TSB should have been a recall, no fuel in remote areas, or running out of fuel at highway speeds is a safety issue.
