Originally Posted by brillo_76
I seen that area rotted out on a few of mine. Cracked so it has to be an extreme stress fracture that's going to need welded. You jump the 4 runner or do heavy off roading?
They are only welded on 3 sides with that crossmember tube weld being the weakest.
Not at all!
The weld at the tubular cross member is also has come loose. Dropping the gas tank is not too bad but love to avoid if I can.
How about weld the torn and run two high tensile nuts and bolts from the tubular cross member to shock-mount plate as shown below to avoid the requirement to drop the tank to weld that area?
