Originally Posted by 19963.4lsr5
What is your voltage at the charge post of the alternator?
That light may also come on if the V regulator is failing and outputting too high of voltage.
If your voltage is above 14.5 at the post and you have jumper cables use them to ground the Alt to the negative post of the battery and frame.
14.7 at the alternator post, can you elaborate on the test you mentioned?
