Originally Posted by CO_Fletch
Interesting behavior, testing the voltage in that manner to the fuse box appears to reset something because power is back but then I try to start again and it goes back to disconnect state with the one click. Now trying again, it isn't resetting and the testing polarity is switched - the large wire in fuse box is only reading voltage to + terminal and not to the frame.
When it’s dead you have no headlights?
A high resistance connection will show full voltage with no load.
If my above statement is true then do the test again with the lights turned on and not working. If your battery truly is good you should find a bad connection somewhere. Your lights do not go through the ignition switch.
