I decided to have a friend of mine do the install for the front since it needed some welding and he could get the alignment done all in one go. The
eimkeith
PCK, body mount chop, and rear reservoir install were originally meant for the 4th gen. Those were what I was headed to the shop for when I lost the 4Runner in the first place. In any case, figured I'd save myself the trouble and have him dial it all in for me.
I bought the eimkeith PCK after finding it in this thread:
panhard correction kits 4th gen fix panhard bar angle Bought over 2 years ago... I remember telling him about how the bracket should fit 4th gens if he designed it for the 5th gen axle.
I got these Dirt King LCAs from the classifieds. They came off a 5th gen and I got the sleeves for the 4th gen to end up not even needing them. The other parts came off my 4th gen of course.
I discovered when I first got the FJ home last month, I was missing one of the studs for my rear tire carrier. Also scary was, I made the 800 mile trip with the other two lugs loose. I didn't think to check them prior to getting on the road. Was lucky that it didn't come off. This will also be fixed. I got a bag of black brake bolts (M12-1.5 x 35mm) off eBay meant for a BMW brake job for this. That was the closest length that matched the stock ones. I didn't want to get a hardware store variant because I didn't want to hunt down a black one (didn't want to constantly have to paint it).
Prior to sending her off to the shop I did the first oil change for her in the driveway. Installed my F-133 Fumoto valve that I took off my 4th gen. Same size as most Toyotas since my IS300 also uses the same one. Won't get too deep into it but its a great product.
I did a comparison between the skid plates on my friend's 5th gen and my FJ. Pretty much the same thing. I wanted to see if I bought 2010+ skid plates for a 4Runner, if they would work on my FJ.
Parts are being installed quicker than I can update the thread. That is if I was on as often as I was before.
Part Installed
- Fumoto F-133 valve
Future Parts
- Fox 2.5 extended travel coilovers
- TrueTravel UCAs
- Dirt King LCAs
- eimkeith PCK
- custom BMC
1999 2.7 5MT - SOLD //
2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT //
Model 3 // IS300 5MT //
FD RX7 //
