Originally Posted by meltdown
Inverter will work while driving. You just have to turn it on by pushing the button.
Sorry about my confused post;;I was thinking the OP wanted to use the 400W while driving. Only the 100W works while the vehicle is moving. The 400W works only while the vehicle is stationary and in P or N. Copy from Owners Manual:
■ Maximum available capacity of the power outlet
● While the vehicle is being driven
The maximum capacity of the power outlet is always 120 V AC/
100 W.
● When the vehicle is stationary
The maximum capacity of the power outlet varies depending on
the position of the shift lever.
• The maximum capacity is 120 V AC/100 W when the shift
lever is in any position other than P or N.
• The maximum capacity is 120 V AC/400 W when the shift
lever is in P or N.
The maximum capacity of 400 W can only be restored by turning the
power outlet main switch off and then on again with the shift lever in
P or N.
